New productsNews from the industrial computer sector
What's new in industrial PCs? Our picture gallery shows you the latest products in this area - from conventional embedded devices to USB hubs and specially enhanced Raspberry Pi devices.
The ECW-281BWD-BTI box PC series from ICP has an Intel Celeron J1900 processor and a maximum of 8 GB of DDR3 memory. It also offers interfaces such as a VGA, three USB 2.0, one USB 3.0 and four COM ports as well as eight digital inputs and outputs. According to the manufacturer, this basic equipment is the basis for universal use in the industrial automation sector or as a stand-alone controller. According to the supplier, the computer is suitable for industrial applications thanks to its robust housing and passive cooling concept. The extended temperature range between -20 °C and +60 °C as well as the high vibration resistance in accordance with MIL-STD-810F should enable problem-free operation, even under extreme environmental conditions. Any voltage fluctuations that occur can be compensated for by a variable input voltage of 9 to 36 V(DC). Individuality is guaranteed by simple expansion options - such as fieldbus interfaces - using the two PCIe mini card slots. Optionally, both an IPMI 2.0 and a WiFi function can be implemented using suitable modules.
