Embedded systemsNew products at embedded world 2018
From February 27 to March 1, 2018, the Nuremberg exhibition halls made room for everything to do with embedded systems technology. Computer&AUTOMATION presents a selection of new products that were on show at the stands of the 16th embedded world.
The 12.3-inch IPS TFT display in 24:9 format from SE Spezial-Electronic is suitable for both indoor and outdoor use. According to the manufacturer Winstar, it is characterized by 24-bit color depth and offers the user a wide horizontal and vertical viewing angle of 170° each, a contrast ratio of 1000:1, a high resolution of 1920 x 720 pixels and a luminance of 800 Cd/m². The fully bonded PCAP touchscreen with 1.8 mm thick front glass and black frame has its own Cypress CYTMA568 multi-touch controller with I²C interface. The dimensions of the display are 313.4 mm x 135.86 mm x 10.6 mm, the active area is 292.32 x 109.62 mm². The display is controlled via a dual-channel LVDS interface. An operating temperature range between -30 °C and +85 °C and a storage temperature range between -40 °C and +95 °C should predestine the display for use in information systems and industrial applications outside buildings as well as in vehicles and construction machinery.
