Embedded systemsNew products at embedded world 2017
In mid-March, the Nuremberg exhibition halls made room for everything to do with embedded systems technology. Computer&AUTOMATION presents a selection of new products that were on show at the embedded world 2017 stands.
13 of 29
17_Embedded Box PC series BP-ECS9700-GTX950/BP-ECS9600-GTX950 from Plug-In
© Plug-In Electronic
Plug-In presents its latest Embedded Box PC series BP-ECS9700-GTX950/BP-ECS9600-GTX950 with the new Nvidia graphics processor GeForce-GTX-950, whose Pascal architecture enables the control of up to 7 independent HD displays or 6 independent Ultra HD 4K displays. The series is equipped with the Intel Xeon Core processor (Skylake-H) and the Intel CM236 chipset and can accommodate up to 32 GB of ECC memory with dual-channel DDR4 2133 MHz. Multiple SATA-III (6GPs), USB 3.0 (5Gbps), PoE (1Gbps) LAN and wireless connections enable data transfer. The computer systems can be used in an extended temperature range of -40° degrees to +60° degrees. A power supply from 10V to 36 V DC with 80V overvoltage protection should also ensure reliable use in a wide range of applications.
13 of 29
