Compmall
Flat and powerful embedded PCs
With its dimensions of 356.5 mm x 222 mm x 44 mm, the Flex-BX100-ULT5 embedded PC from Compmall is very flat
Embedded PC Flex-BX100-ULT5 from Compmall
© Compmall
Nevertheless, according to Compmall, the embedded PC offers high computing and transmission performance. You can choose between 8th Gen. Intel Core i5-8365UE, a four-core processor with 1.60 GHz base clock and 4.10 GHz burst, and 8th Gen. Intel Celeron 4305UE, a two-core processor with 2 GHz base clock. Both processors have a power dissipation of 15 W, so that the system could be built without a fan. Up to 32 Gbyte of DDR4 SO-DIMM memory is provided. Two 2.5-inch HDD/SSD SATA slots are available for mass storage.
Integration into networks takes place via three Ethernet ports, two of which are PoE-capable if a corresponding module is integrated. External devices are connected via four USB 3.2 Gen2 ports or via RS232 and RS232/422/485. A monitor with a resolution of up to 4K can be connected via HDMI.
Compmall
Embedded PC DV-1000
The DV-1000 embedded PC from Compmall is fanless, robust and compact. With a mounting kit, the PC can be attached to the DIN rail to enable applications in factory automation, logistics for controlling autonomous mobile robots or image processing
