Switches
Quelle: Spectra | Inka Krischke,
Temperature range from -40 to +70 °C
With the IGPS-9080-24V, Spectra offers a compact 8-port Ethernet switch with PoE (30 W per port) and Gigabit Ethernet for industrial use.
© Spectra
A robust metal housing, DIN rail mounting and an operating temperature range of -40 to +70 °C are just some of the switch's features. While PoE switches usually require a power supply of 50 V(DC), this device has two redundant power inputs from 12 to 57 V(DC). Redundant data streams are ensured by the administrability, which enables a ring structure to be set up with <30 ms recovery time. Additional functions such as jumbo frame, PoE auto-ping check and IP-based bandwidth management are also available.
Indu-Sol
A switch especially for automation
Indu-Sol Managing Director Karl-Heinz Richter is convinced that switches from the IT world do not always meet the requirements of automation technology. The network specialist from Schmölln is therefore now coming up with its own solution.
QNAP Systems
Next-Generation Switches
QNAP has announced the new generation of its QSW-M2130 L2 Web-Managed Switch series. It is available in two models—the standard model “QSW-M2130-4C2S24T” and the PoE++-capable model “QSW-M2130P-2C2S26T.”
Weidmüller
Dr. Sebastian Durst becomes CEO
The Weidmüller Group is strengthening its first management level as of October 1, 2024: Dr. Sebastian Durst, previously Chief Operations Officer, will take over the newly created position of Chief Executive Officer (CEO).
HMS Networks
Cybersecurity for industrial networks
With 'Anybus Defender', HMS Networks presents a new product range for the highest cyber security requirements in industrial environments. The new product range offers protection for networks in the manufacturing industry and for the critical...
