OPC UA
Meinrad Happacher,
OPC UA in mature mode
A global standard for the Internet of Things - the OPC Foundation believes that OPC UA is the best way to achieve this goal. A cross-section of the Foundation's innovations at this year's Hannover Messe in April and beyond.
© OPC Foundation
The OPC Foundation continues to grow in popularity. As of 24 April, the organization has 602 member companies - and the trend is rising. When announcing new developments, Stefan Hoppe quickly moves on to one of the most important topics that has been implemented: In February, the OPC Foundation released Part 14 of the OPC UA standard: known as Publish-Subscribe or 'PubSub' for short. The specification expands the scope of OPC UA to include a wide range of additional use cases down to the lowest field level.
Stefan Hoppe: "The new PubSub extension takes the OPC UA Eco system to a new level."
© Computers & AUTOMATION
In addition to the existing request/response procedure, which requires a 'standing' connection between OPC client (data consumer) and OPC server (data provider), there will be another communication mechanism based on the publish-subscribe principle in the future. This will allow OPC UA to be used in other application areas. For example, in sensor networks and cloud applications, a large number of devices typically send their data to one recipient (many-to-one). With the publish-subscribe method, a publisher (OPC server) sends its data into the network without a connection and many subscribers (clients) can receive this data without the need for a resource-intensive connection. In the Industrial Internet of Things (IIoT) and also in Industry 4.0 applications, communication can be realized via brokers in the cloud. Here, many hundreds or even thousands of devices can publish information and subscribers receive the messages from the broker in the cloud. Standard protocols such as AMQP and MQTT are used for this. In addition to a sensor or cloud connection in a many-to-one scenario, connectionless pub/sub communication offers further advantages. In local communication between known participants, such as industrial control systems, only small amounts of data often need to be transferred. In many cases, response times must be guaranteed and thus deterministic real-time requirements must be met. To achieve this, pub/sub communication is to be combined with the new Ethernet extensions for Time Sensitive Networks (TSN). Real-time communication between controllers from different manufacturers is then possible via TSN-capable network components (switches).
According to Stefan Hoppe, the first PubSub implementations could be realized in 8-bit controllers with only 2 kByte SRAM.
Euromap 77
Regulating the exchange of data between injection molding machines and host computers or MES - that is the aim of the newly published Euromap 77 standard. Specifically, Euromap 77 is the first OPC UA-based standard for digital interfaces in the field of plastics and rubber machines. Euromap 77 was published on May 4 and is available for download at http://www.euromap.org.
In order to increase production efficiency, more and more plastics processors worldwide are relying on the digital networking of machines and components. Equipment from different manufacturers is used in most production facilities. If the processor can rely on standardized interfaces for networking, the high configuration effort involved in adapting individual solutions is eliminated. Euromap, the European Committee of Plastics and Rubber Machinery Manufacturers, is developing these standards for cross-manufacturer communication based on OPC UA. OPC UA enables communication between acting and sensing systems and is therefore an important component of Industry 4.0," confirms Jonas Schwarz, Product and Technology Manager at Krauss Maffei.
Compared to its predecessor Euromap 63, the Euromap 77 standard offers an extended range of functionalities. With Euromap 77, machines from different manufacturers can be networked with significantly less effort, for example for monitoring, process data acquisition or job management. Prototype implementations of the release candidate have been available since spring 2018: The standard was tested during two plugfests by the companies involved in its development.
Companion specs for drives
The VDMA is currently working hard on Companion Specifications, so-called information models for products and their capabilities. The latest activity in this regard: The Industry 4.0/OPC UA Drive Technology working group started developing OPC UA Companion Specifications for drive technology on April 17. The OPC UA communication architecture serves as the basis for this. As an essential component of many machines and systems, drives determine their costs, energy efficiency and optimization potential in many ways. Intelligent drive components form an active part of Industry 4.0 applications and processes and are therefore the basis for networked services and business models of the future.
For this reason, the new VDMA Industry 4.0 / OPC UA Drive Technology working group has set itself the task of developing manufacturer-independent OPC UA Companion Specifications for the drive system - including the transmission elements. In order to dovetail with existing, relevant activities, the working group is in close coordination with industry-specific OPC UA committees. As an important additional step, the working group plans to join forces with the OPC Foundation as a Joint Working Group.
VDW relies on OPC UA
TSN and OPC UA - an integral part of the OPC Foundation's trade fair stand. The differences between the demo set-up of the IIC and the LNI seem only marginal: The IIC also connects the sensor technology ....... with the Sick products
© OPC Foundation
The VDW, Germany's leading association of machine tool manufacturers, has adopted OPC UA as the basic technology for the development of the VDW's long-term Industry 4.0 strategy.
strategy of the VDW. The VDW represents over 120 medium-sized companies in the machine tool industry and cooperates with the OPC Foundation and leading suppliers such as VDW members Chiron, DMG Mori, Emag, Grob, Heller, Liebherr Verzahntechnik, United Grinding, Trumpf and their control suppliers such as Beckhoff, Bosch Rexroth, Fanuc, Heidenhain and Siemens. As a first common goal, this group of companies will establish an open, consistent OPC UA-based mapping for cross-manufacturer and cross-machine communication to exchange context-rich data with each other and with extended enterprise and cloud-based IT infrastructures. Dr. Heinz-Jürgen Prokop, Chairman of the VDW, explains: "Our goal is the end-to-end networking of production; the vehicle for this is OPC UA and the energy that drives us is the jointly defined equal share of data that we need to exchange to achieve this."
..... into the TSN-OPC-UA communication (image left); the LNI still limits this to the controller-controller level. The technical goal is to connect both testbeds via an Ethernet cable and operate them together.
© OPC Foundation
With the VDW's decision to use OPC UA as an interoperability platform for machine tools and to standardize their information models, the VDW is addressing two key challenges that machine builders must face in order for them and their customers to realize the value of Industry 4.0-enabled machines. Firstly, open communication is needed to exchange raw, context-rich machine data in production environments with different machines and different control systems. Until now, this has not been possible due to the number of proprietary and incompatible data models and protocols used by both machine builders and higher-level automation providers. The definition of common OPC UA information models for machine tools and the use of OPC UA functionality for data connectivity should solve this problem.
Thomas J. Burke is delighted about the cooperation with the VDW: "We will make huge progress in the seamless interoperability of products from machine builders and automation suppliers."
Secondly, machines need a secure connection to the 'rest of the world' which can, however, regulate access and therefore offer authentication and access protection. Data may also need to be pre-compressed and buffered, as raw data in higher resolution cannot be sent through the network in real time without affecting machine performance. All these functions are performed by a gateway, which is specified and implemented as the second project phase.
Thomas J. Burke, President of the OPC Foundation, explains: "The OPC Foundation is pleased to work with the VDW to develop a corresponding OPC UA Companion specification from the VDW's comprehensive, predefined data model that will enable members of the OPC Foundation and the VDW to easily and quickly develop certified products that will dramatically expand seamless interoperability between machine builders and automation suppliers."
The ZVEI cooperation
The OPC Foundation and the ZVEI (German Electrical and Electronic Manufacturers' Association) signed a Memorandum of Understanding at the Hannover Messe trade fair on joint activities relating to Industrie 4.0. The first focus is an OPC UA-based mapping of the Industry 4.0 administration shell - 'I4AAS' for short (Industry 4.0 Asset Administration Shell).
Gunther Koschnick and Stefan Hoppe seal the joint activities of the ZVEI and the OPC Foundation in terms of Industry 4.0.
© OPC Foundation
Under the umbrella of the OPC Foundation, the previously technology-independent concept of I4AAS is mapped to the technology of OPC UA. The conceptual basis of the I4AAS is the result of Platform Industry 4.0 Working Group 1 'Norms, Standards and Reference Architecture', the ZVEI mirror committee 'SG Standards and Models' and the ZVEI project group 'Administration Shell in Detail'. To ensure the interoperability of the I4AAS with the OPC UA Companion specifications - developed by the VDMA - the VDMA is another partner in the new joint OPC working group alongside the ZVEI.
Gunther Koschnick, Managing Director of the ZVEI Automation Association, says: "Industry 4.0 is in the implementation phase. The implementation of the I4.0 administration shell in OPC UA takes the Industry 4.0 vision of interoperable communication between components and equipment a significant step forward."
And Stefan Hoppe adds: "The OPC Foundation is aiming to define the Industry 4.0 administration shell technically as the OPC UA Companion Specification I4AAS." Seven well-known groups are currently working on prototype implementations of the I4 administration shell based on OPC UA. The future joint I4AAS working group aims to harmonize all these activities, but also to coordinate with other interest groups - such as the VDMA - in order to synchronize the I4AAS with the 'VDMA Mechanical Engineering CS Type A' initiative, for example - which defines the basic properties and functionalities of the mechanical engineering industry.
TSN
Arrive in reality!
Time Sensitive Networking has firmly established itself in the vocabulary of the automation industry. All well-known suppliers have started activities to evaluate or even introduce TSN. But where exactly are the goals for the use of TSN and what is...
Industry networks
OPC UA and DDS combined
To date, OPC UA and DDS have often been presented as competitors. Competitors that will both be based on the Ethernet standard TSN. - However, the key to successful automation in the future lies in a combination of the three standards DDS, OPC UA...
AS-Interface
Data pipeline ASi-5
High data width, short cycle times, improved integration of intelligent sensors and actuators using IO-Link and cloud connectivity via OPC UA - ASi-5 makes AS-Interface fit for the requirements of digitalization.
Standards
OPC UA, MQTT and co.
The Industrial Internet of Things (IIoT) covers very different areas of application. The available connectivity technologies and standards are just as diverse as the application areas. How can the right technology be filtered out in each case?
TSN
The question of licenses
Will OPC UA in combination with TSN become 'the' standard for industrial communication? What role do licenses play in this question and what part does OSADL play?
