Bihl+Wiedemann
Integrated safety unit up to SIL3
The BTL-certified ASi BACnet/IP controller with integrated safety unit up to SIL3 BWU4001 from Bihl+Wiedemann combines the advantages of BACnet, ASi and ASi Safety in one device.
© Bihl+Wiedemann
This makes it suitable for controlling safe fire protection and smoke extraction dampers, for example. All data from the field level is available in BACnet via the ASi BACnet/IP controller, without the need for additional 'converters'.
The device, which has two ASi masters and an integrated safety unit, can be used as a stand-alone small controller for safe fire and smoke dampers, which typically achieve a safety level of SIL2. However, it can also be connected to a higher-level BACnet DDC or GLT and thus act as a gateway between the control system and the ASi installation. Diagnostic functions for fast system analysis are then available via BACnet, web server or as a plain text message on the gateway's integrated display.
Bihl+Wiedemann at the SPS 2021: Hall 7, Stand 200
Bihl+Wiedemann
Perfect mix of ASi-5 and ASi-3
Automated material flow lines in modern conveyor systems are often several kilometers long. Standard and safety signals as well as simple and complex tasks need to be managed here. Combinable ASi-5 and ASi-3 solutions are predestined for these...
Bihl+Wiedemann
First ASi-5 safety modules
With the BWU4209 input modules for potential-free contacts and BWU4210 for optoelectronic protective devices, Bihl+Wiedemann presents the first products with ASi-5 safety technology for complex safety sensors and applications.
Bihl+Wiedemann
Innovation partner for automation
Bihl+Wiedemann is a medium-sized, owner-managed company - founded in 1992 by Jochen Bihl and Bernhard Wiedemann in Mannheim. It develops and manufactures complete solutions for functional safety and data communication in machines and systems.
Bihl+Wiedemann
Easy integration into AS-i networks
Bihl+Wiedemann has developed an ASi-5/ASi-3 manual addressing device that can be used for all ASi-5 modules as well as for all modules of earlier ASi generations in order to easily integrate ASi participants of all generations into ASi networks in...
