Ethernet IO modules
Integrated IO-Link master function
The Ethernet IO modules from Pepperl+Fuchs support common Ethernet protocols such as Profinet, Ethernet IP and Ethercat in one device. Thanks to the integrated IO-Link master function, end-to-end diagnostics and parameterization are possible.
An L-coded M12 power connector offers up to 16 A current and reduces the installation effort. The multi-protocol function enables standardization in the machine, where previously different module types were required. A rotary selector switch is used to switch between the Profinet, Ethernet IP and Ethercat protocols. The integrated web server enables downloads, parameterization and diagnostic display. IO-Link-capable sensors and actuators can be connected, configured and parameterized via the integrated 8-fold IO-Link master. The fully encapsulated metal housing complies with protection class IP65/67/69 and measures 200 mm in length and 18 mm in height.
