Softing
Building flexible IIoT solutions
Version 2.31 of Softing's edgeConnector products supports MQTT subscriber functionality. The product family currently includes edgeConnector Siemens, edgeConnector 840D and edgeConnector Modbus.
Software modules from Softing based on Docker technology
© Softing
Softing 's software modules based on Docker technology provide access to process data in Simatic S7, Sinumerk 840D and Modbus TCP controllers. MQTT can be used to make the structure of IIoT solutions more flexible. For example, recipe management can be implemented from the cloud or at the edge by receiving data from an MQTT broker and writing it to a controller. Predictive maintenance via the MQTT protocol is also possible. In addition, the Monitor & Optimization (M&O) application can be used to change variables in the production process as soon as M&O has identified optimization potential. Thanks to the use of container technology, the products are quickly ready for use. They are operated on standard hardware and can be administered centrally. All edgeConnector products support security standards such as SSL/TLS, X.509 certificates, authentication and data encryption.
Softing Industrial Automation
PLC data in the cloud
Machine data is fodder for industrial IoT applications. However, collecting it is not trivial and is linked to operating processes and the organization of an overall IIoT solution. What are the benefits of centralized data collection management and...
