Advertorial
Cognex | Tiffany Dinges,
Image processing made easy
The Cognex In-Sight 2800 vision system combines deep learning technology with traditional rule-based vision tools to handle a variety of applications at all skill levels without programming expertise.
© Cognex
The In-Sight 2800 provides an easy-to-implement defect prevention solution that ranges from simple presence/missing inspection to sophisticated categorization and sorting tasks. Cognex delivers a solution that is suitable for all skill levels, regardless of previous machine vision or programming experience.
© Cognex
The comprehensive vision tool set performs tasks of varying complexity and can be used individually for simple tasks or interconnected to solve more difficult logic sequences.
Designed for factory automation, the In-Sight 2800 enables manufacturers of all sizes to
  • Improve product quality - detecting small, subtle defects using optimized defect detection.
  • Maximize operational efficiency - Make the most of existing staff and keep production lines running continuously with fast, intuitive job setup.
  • Streamline integration - No more fiddling with image optimization, identify the correct combination of accessories with just a few clicks.
Unlimited classification outputs for ultimate customizability
© Cognex
Ask for more than just OK/NOK. The powerful ViDi EL Classifier tool recognizes and sorts parts based on multiple characteristics or properties. This allows you to classify defects into different categories and correctly identify parts with deviations. In addition to assigning multiple classifications, you also have the option of setting multiple target areas to be checked and checking different areas of your image with a single shot.
Easy setup thanks to EasyBuilder development environment
© Cognex
The EasyBuilder development environment simplifies setup and ensures a short turnaround time. Connect the In-Sight 2800 and get results in just a few minutes - without any prior programming knowledge. The intuitive EasyBuilder development environment guides users step-by-step through the application setup and enables a quick turnaround time from proof of concept to deployment.
Powerful and adaptable lighting for optimized images
Left: Actual part; center: red light (blurred numbers); right: blue light (sharp numbers)
© Cognex
To capture high-resolution images of all products in all environments, the In-Sight 2800 offers multi-color (RGBW) illumination for optimized image formation, maximum contrast and maximum illumination under all operating conditions.
Modular, scalable architecture for current and future requirements
The Cognex In-Sight 2800 can be modified with retrofittable components and adapted to numerous application settings and customer-specific requirements. This modularity allows manufacturers to quickly adapt it to new parts and meet changing requirements.
More information and examples of possible applications.
Follow Cognex also in the social networks
IDS
AI and streaming meet robustness
IDS Imaging Development Systems is expanding its range of AI cameras with the 'IDS NXT oslo'. The model combines artificial intelligence with video streaming and recording functions in a compact, industrial-grade housing.
Digital Twins
With real-time data against disasters
A digital twin is more than just a two- or three-dimensional digital copy. It combines precise data with intelligent analysis and solves complex challenges. With locations in Paderborn and other cities, Eviden relies on the combination of artificial...
