Steinmeyer Mechatronics
Matthes Elger | Inka Krischke,
Focus misaligned?
Extremely short distances, as are typical in focus adjusters for automatic inspection in production plants, place high demands on the technology. A rather unconventional approach helps to prevent them from becoming a major challenge.
If the angle of rotation of the motor is limited to ±45° from the horizontal position of the eccentric, the movement is linear, repeatable and easy to control.
© Steinmeyer Mechatronics
Camera systems used in industry for automatic inspection and quality assurance must focus in a matter of seconds: A maximum of 100 ms is usually available for this. Although the travel distance of 0.5 to 2 mm is not particularly large - it is often only a matter of compensating for the thickness variation of a substrate or capturing narrow stacks of images at different depths of field - this short distance can quickly prove fatal for standard focus adjusters based on linear guides. This is because the tribological system of mechanical roller guides fails prematurely with millions of small movements, as the lubricant is displaced at the contact point and cannot be distributed over the entire raceway as is usually the case. This results in cold welding, which blocks the adjuster. With movements in the micrometer and sub-micrometer range, stick-slip effects also have a negative impact, i.e. the transition from static friction to rolling friction in the guideway.
The focus adjusters consist of a spring parallelogram, an eccentric drive with stepper motor and an inductive linear measuring system
In classic microscopy, piezoelectric focus adjusters have proven themselves for applications with short distances and high numbers of cycles. However, although these allow high dynamics with good step resolution, they are extremely sensitive to handle and expensive to purchase. They also require a special high-voltage interface for electrical control. This makes them unattractive for use in industrial applications.
Rethinking familiar solutions
Travel and parasitic movement in the spring parallelogram.
This is where Steinmeyer Mechatronik comes into play with a focus adjuster consisting of a spring parallelogram, an eccentric drive with stepper motor and an inductive linear measuring system. At first glance, this combination may seem rather strange to mechanical engineers: leaf springs as a guide element? Eccentric drives and accuracy? However, such reservations are unfounded.
Leaf springs originally come from metrology, where they have been used for over a century, and the high-tech industry also makes use of the principle. In general mechanical engineering, however, solid-state joints are rarely used. In the form of a spring parallelogram, this is a sensible solution, especially for extremely short travel distances: with small longitudinal movements, the leaf springs deform elastically so that there is no risk of wear or fatigue fracture. The upper platform performs the desired linear movement. Vertically, the shortening of the leaf springs during deflection results in a parasitic movement that is predictable, systematic and can therefore be compensated for.
If this is not acceptable, the leaf spring can be designed as a rotationally symmetrical diaphragm spring. In this case, the material expansion eliminates the parasitic movement. However, diaphragm springs require significantly more space compared to leaf springs, which is an exclusion criterion for many applications.
For very small travel ranges, diaphragm springs are flat sheet metal ends; for larger travel ranges, they are slotted or fitted with circumferential beads. When correctly dimensioned, solid-state joints allow permanent linear movements with small deflections and a long service life. They require no lubricant, operate friction-free - regardless of internal material friction - and do not exhibit any hysteresis or stick-slip effects.
Ancient technology, modern system
The concept of the eccentric drive is also well known - the technology was already used in ancient times for the transformation between a rotational and a linear movement. Today, eccentric drives can be found in presses and clamping devices, but also in car combustion engines in the form of the crankshaft. The use of eccentrics enables a simple, robust and inexpensive solution, but has its pitfalls in terms of linearity and control. For example, the system behaves non-linearly during a full revolution in the vicinity of the reversal points. This results in a reversal of the linear movement with the same direction of rotation of the motor.
Steinmeyer Mechatronik has used a simple trick to prevent this undesirable effect: Instead of performing a full rotation, the motor's rotation range is restricted. If the angle of rotation of the motor is limited to ±45° from the horizontal position of the eccentric, the travel distance is reduced by around 30%. At the same time, the highly non-linear areas are suppressed and the reversal of direction in the transmission behavior is prevented. This means that the solution only moves in the range that is clear, repeatable, linear and easy to control. The resulting deviation from a linear transfer function with these limit values is a maximum of 4 %, which is only reached in the end ranges of the travel path. On average, it is 1.5 %. If the limits are selected more narrowly, an even better linear behavior of the system can be achieved at the expense of the adjustment travel. As these deviations are systematic, they can be compensated for in higher-level software. Stepper motors should typically be used, as they can absorb external torques at standstill. A high reduction gearbox is recommended for servomotors, but this contradicts a simple and cost-effective design.
Detection of the current travel distance
The author: Matthes Elger works in development and product management at Steinmeyer Mechatronik in Dresden.
Steinmeyer Mechatronik uses an inductive linear measuring system designed as an SMD component as a measuring and feedback system. It is largely immune to contamination, oscillations and vibrations as well as electrical and magnetic fields and therefore enables reliable operation in an industrial environment. It also meets the requirement for a standard data interface that can be read and processed immediately by the control components. Interpolation rates of 12 bits and more allow a resolution in the sub-micrometer range. By using two read heads on scales with slightly different period lengths, the incremental systems can be configured as cost-effective absolute measuring systems. An internal calibration ensures an absolute accuracy of 10 µm over the entire travel range. As the control electronics always measure the actual position of the moving lens, additional compensation of eccentric non-linearities is unnecessary.
MVTec
Dynamic OCR Inspection
Due to strict compliance regulations, packaging containing medical products must be correctly labeled before it is delivered to customers. The Chinese company Shenzhen Jiangrun Xuneng Technology has developed a sophisticated image processing...
