SPS Connect
Andrea Gillhuber | Andrea Gillhuber,
Roland Bent from Phoenix Contact in a short video interview
In this video interview, Roland Bent, CTO at Phoenix Contact, talks about the coronavirus pandemic and why interoperability and openness are so important in times of the Industrial IoT.
© Phoenix Contact
You can also find out what he considers to be the most impressive developments presented at the SPS.
More from Roland Bent? Here you can also read the report on the press conference of the ZVEI Automation Association at SPS Connect, which dealt with overcoming the corona crisis, digitalization in companies and the forecast for the coming year 2021.
Phoenix Contact
Retired CTO
Roland Bent, CTO of Phoenix Contact, ended his professional life on February 28. His core responsibilities will be assumed by CDO Frank Possel-Dölken from March 1, with a focus on the digitalization of Phoenix Contact.
Phoenix Contact
System availability ensured
Even if only one component fails, the entire machine or system can - in the worst case - come to a standstill, as their functions are usually closely interlinked. To prevent this worst-case scenario, every fault must be safely shut down.
