Beckhoff
Günter Herkommer,
Engineering directly in the cloud
Beckhoff is presenting 'Twincat Cloud Engineering' at SPS 2019. The new solution allows the existing engineering and runtime products from the Verl-based company to be instantiated and used directly in the cloud.
Sven Goldstein, Beckhoff: "With Twincat Cloud Engineering, even globally distributed control systems can be easily operated and maintained remotely."
© Computers&AUTOMATION
Access to 'Twincat Cloud Engineering' is easy via the Beckhoff website, which means that no additional software components are required apart from a web browser. In this way, registered users can even work with the Twincat development environment via previously unsuitable platforms, such as tablet PCs.
According to Sven Goldstein, Product Manager Connectivity & IoT at Beckhoff, communication from the virtual to the physical world with real control hardware can take place either via Secure ADS or ADS-over-MQTT: "The data connection is secured via standard security mechanisms such as TLS with certificates."
The only difference between cloud-based engineering and the conventional approach is the use of a virtual machine instead of a local engineering PC. This means that users do not have to get used to a new software environment, but can continue to work in their familiar development environment. Another advantage of the solution is that there is no need to install and maintain different software versions tailored to the individual machine generation on the user's own PC. Instead, various cloud engineering instances with different versions can be used; they can be accessed remotely and as required.
A source code control repository, which can be accessed directly from engineering, serves as a project repository. Goldstein comments: "Git-based systems can be easily connected via modern source control functionalities and used to manage the automation project. The multi-user function enables simple and seamless access to the source control repository without the need for in-depth user knowledge."
One click to the dashboard
Increasing engineering efficiency is also the aim of another innovation from Beckhoff: the One-Click Dashboard for Twincat Analytics. With a simple click, a complete HTML5-based analysis dashboard is generated on the basis of the PLC code and loaded into the selected Analytics runtime. The user receives the corresponding network address where the dashboard can be queried via a web browser - without having to write a single line of code or do any graphic design themselves.
This function is based on Twincat 3 HMI and offers at least one separate HMI control based on the latest web standards in a modern tile design for each analytics algorithm. The available controls can be selected in the respective properties of the algorithms with a corresponding control preview. Several algorithms can also be combined in one control.
OPC UA
On the way to the world library
The vision has been in place since the end of 2014: OPC UA is to achieve the status of a globally recognized standard for the Industrial Internet of Things IIoT by 2019 at the latest. During the press conference at SPS, the Foundation took a stand...
Turck
More investment in software expertise
The economy is leaving its mark: compared to the previous year, Turck expects total sales of around 640 million euros for the 2019 financial year, a decline of 3%. Nevertheless, Managing Director Christian Wolf is optimistic.
SPS 2019
A look back at the fair
The 30th SPS was the highlight of the automation industry at the end of November. The keywords 'digitization' and 'digital transformation' were visible right through the halls. The main trends can be seen in the film below.
Video
SPS 2019 in retrospect
The 30th SPS, the trade fair highlight of the automation industry, took place at the end of November. The buzzwords 'digitalization' and 'digital transformation' were visible throughout the halls - the most important things in the film.
Sieb & Meyer
Dynamically driving high speed motors
Under the name SD4x, Sieb & Meyer is developing a new generation of frequency inverters for high-speed applications. The first of these is the SD4S version, which is designed for small high-speed spindles and motors with a power output of just a...
IniNet Solutions
Industry 4.0 'off the shelf'
iniNet Solutions has developed an automation architecture based on web server-supported SCADA and programming software, which is intended to bring manufacturing companies more easily than ever to industry 4.0 level. This architecture can be seen at...
CloudRail
Plug and play into any cloud
A year ago, Cloudrail unveiled the 'CloudRail.Box' for the first time - a gateway that connects plug-and-play to IO-Link sensors and masters and sends the data to any cloud platform. Now it also handles OPC UA and Edge Computing.
R3 Communications
Manufacturing without cables
R3 Reliable Realtime Radio Communications presents its first series products "Echoring Ethernet Bridge" (EREB) and "Echoring System on Module" (SoM) at the SPS. They are intended to complement wired industrial Ethernet networks with equally powerful...
