13 of 15
11_Modular Conmaxx cable entry system from Wiska Hoppmann
© Wiska Hoppmann
The modular Conmaxx cable entry system from Wiska is particularly suitable for control cabinet installations and electrical enclosures. Three components - different frame sizes, grid inserts and conical sealing elements - can be individually combined depending on requirements and area of application. According to the supplier, the modular system with a closed frame and optional split sealing elements enables simple installation from the inside of the enclosure to the outside, so that subsequent, individual changes to the cabling can also be made without unscrewing and screwing the frame. Around 100 different sealing inserts, four frame sizes and four grid inserts enable flexible and individual electrical installation.
13 of 15
