The Ölflex Chain 90 P/CP belongs to Lapp's "Extended Line Performance" class and is designed for use in continuously moving drag chains. The cable with extended maintenance intervals has a highly abrasion-resistant and notch-resistant PUR outer sheath and a cold-flexible special core insulation made of TPE. This makes it equally suitable for indoor and outdoor use - for example in industrial drives, but also in wind turbines or electric cars, where limited space usually requires very tight bending radii. The cable is resistant to mineral oil-based lubricants, UV and weather-resistant, halogen-free and highly flame-retardant. It is also UL/cUL-certified and therefore approved for use in North America. The cable is available in an unshielded (P) or shielded (CP) version.
