10 of 15
Enclosure light from Rittal
© Rittal
Rittal is completing its range of enclosure lights with two versions of the LED system light. In addition to the 1200 and 900 lumen versions, the luminaire series specially developed for enclosures is now also available with 600 and 400 lumen light output for smaller enclosure and housing systems. The 600 lumen version meets the standard requirements for the TS 8 large enclosure and the 400 lumen version meets the requirements for wall-mounted enclosures. Optics made of transparent plastic with integrated Fresnel lenses provide optimum illumination of the enclosure. These focus the light in such a way that it illuminates the entire enclosure in a targeted manner, even in the lower area. This ensures that the light reaches exactly where it is needed without scattering into the outside area. All lights are designed for wide-range voltage - 100 to 240 V(AC) - and can therefore be used worldwide. The luminaires can be adapted to any installation situation and installed both vertically and horizontally in the enclosure profile.
10 of 15
