Product presentationsNews from the field of electromechanics
There are two new variants of the 'BoTouch' enclosure series from Bopla: BoTouch BTK-IP 4.3 and BTK-IP 10.1 are designed for the installation of commercially available 4.3 and 10.1 inch capacitive touch displays. According to the manufacturer, a finer adjustment between the display and housing results in a significantly narrower display frame. Protection class IP65 is achieved by providing the rear of the housing with a foamed PU seal and closing it with a back plate. The glass front is also glued into the housing. As a panel mounting enclosure, 'BoTouch BTK-IP' also has a foamed PU seal in the front frame. The 'Filotec' product line is also suitable for the embedded sector thanks to its heat sinks. With a new size of aluminum profile housing (F 1632-xxx), the manufacturer is meeting the requirements of users who also want to install large-format PCBs. The internal dimensions of the enclosure are designed for the installation of a Eurocard (100 mm × 160 mm) in landscape format.
