Energy chains
Lukas Czaja | Günter Herkommer,
How vibrations can be reduced
In view of constantly increasing demands on the process accuracy of machine tools, vibrations in the system must be reduced to a minimum. An effective starting point here is to improve the smooth running of cable carriers in dynamic applications.
© Igus
Dynamic loads generally cause vibrations that can cause the tool and workpiece to shift during machining. This limits the cutting performance. If the cutting conditions of cutting machine tools increasingly deteriorate, this can lead to process instability. In other words: so-called chatter vibrations occur, which lead to a loss of quality in the machining result and increased wear of machine components. As materials that are increasingly difficult to machine are being used and at the same time the market is demanding ever higher cutting performance for the same machine size, the use of lower-vibration machine components is more urgent than ever.
One possible source of disruptive vibrations are the 'umbilical cords' of modern machine tools - i.e. the energy chains. The more automation is used, the more extensive the use of cables and hoses that have to be routed via energy chains. And the necessary travel movements inevitably cause vibrations at the support trough and the carrier.
Most of the energy chains currently in use are equipped with a pin-bore connection. This fixed connection offers robust protection against external influences, withstands high bending stress and has a high tensile strength and mechanical load capacity. However, the disadvantages are the resulting relative movements between the joints and the resulting susceptibility to wear of the moving parts. The so-called polygon effect also occurs when the cable carrier unwinds. This means that the chain does not run completely round in the bending segment. As a result, the chain links are bent and a polygon is formed from a circle that is ideal for the movement.
Cross-section and frontal view of an energy chain with the 'neuralgic' vibration points of the carrier and support trough.
© Igus
In addition to increased abrasion, this results in a higher level of vibrations in the longitudinal and transverse directions. In the worst case scenario, the resulting vibrations can lead to a resonance catastrophe due to excessive vibration amplitudes, ultimately resulting in material breakage. But even in less extreme cases, the polygon effect can lead to material wear and poorer production results on the workpiece due to the vibrations.
There is a special problem with conductive cable carriers, as the pin-hole structure leads to air gaps. These gaps impair the constant conductivity of a chain, so that even with a material with continuous conductivity, continuous conductivity is not guaranteed. This makes it problematic to use in explosion-proof environments and in product areas that require ESD immunity. In short, although the bolt-hole system has proven to be a reliable form of connection in the past, its geometric and kinematic properties mean that it reaches its limits in terms of abrasion, vibration and discharge behavior.
Spring element instead of rigid connection
With this in mind, every manufacturer strives to improve the vibration behavior of their energy chains. Most manufacturers focus primarily on the small pitch of the links for quiet and smooth running. Igus also follows this approach of small pitch as a design principle, but has also designed a special connecting component for the chain links: an elastic spring element made of high-performance plastic. Instead of the conventional, relatively rigid connection of pin and hole, this results in flexible connectivity, which largely reduces the polygon effect during unwinding thanks to its improved geometry. Extremely low noise levels and almost vibration-free running of the chain are thus possible. Especially in combination with a linear motor, whose drive concept is also designed for low vibration, the vibration behavior is thus reduced to a minimum.
The spring element makes the chain more elastic without losing traction.
© Igus
The E6.29 energy chain variant, which was subjected to a long-term test with over 400 million complete bends in the Igus technical center, is equipped with such an elastic spring element. According to an expert opinion from the Cologne University of Applied Sciences, none of the connectors used exhibited any visible or measurable damage.
The spring element also supports the modular design of the energy chain. The links of the chain side sections can be quickly connected or disconnected by inserting or removing the springs, so that the cable carrier can be easily adapted to the individual requirements of the respective application, fitted with cables and assembled. The chain can be opened in both the inner and outer radius. A plastic hammer, a screwdriver and a few hand movements are all that is needed to drive the connectors in or out. Last but not least, the internal layout can be variably determined by using dividers and divider bars as well as insertion and intermediate shelves, which enables individual feeding and quick cable installation. And the additional use of base and cover elements means that the energy chain can be converted into a closed tube without the need for time-consuming conversion work, offering special protection against dirt, chips and other environmental influences.
The smooth running of a chain equipped with elastic spring elements is also reflected in low noise levels and a measured sound pressure level of just 37 dB(A), as confirmed by an expert opinion from TÜV Rheinland. Manufactured from the electrically conductive material 'igumid ESD', the spring elements can also ensure a permanently constant conductivity and thus discharge capacity if required.
The new generation of smooth-running energy chains has an even smaller pitch and features a 'brake' in the stop system.
© Igus
Another way to reduce vibrations in a machine tool is through special design solutions. One example of this is the arrangement of energy chains on top of each other, which can significantly improve milling accuracy in individual cases. In addition to these 'inherent' solutions, which change the system properties of the machine, additional systems can be integrated that specifically use external forces to minimize or completely avoid harmful vibrations by damping or eliminating vibrations. A distinction can be made between passive and active auxiliary systems:
In passive systems, the damping effect is achieved by converting the vibration energy by means of an additional mass body converting the kinematic energy into thermal energy or a relative movement between the bodies. In active auxiliary systems, an externally supplied auxiliary energy is used to generate an antiphase vibration. However, both methods always mean additional costs, precisely because the additional systems can usually only be realized as special individual system solutions and cannot be used across machines. In the future, therefore, attention should primarily be paid to the sources of vibration, i.e. the low vibration level of the machine tool components.
Technological outlook
The new E6.1 series is a further development of the E6 energy chain mentioned above. In addition to a smoother interior and a weight reduction of around 30 %, it also brings a further improvement in quality in terms of vibration behavior. Thanks to the smaller pitch and a 'brake' in the stop system in the form of a wedge-shaped contour in the e-chain stop, the sound pressure has been reduced by a further 2 dB(A). In addition, the geometry has been optimized, making the run even 'rounder' and virtually eliminating the polygon effect. Also new: the opening bars have been rounded off, as have the transitions from the chain link to the opening bar. All gating and marking points are now outside the chain cross-section. In this way, the contact surfaces and therefore abrasion and vibration have been further reduced. Even at higher accelerations and speeds, this further increases running smoothness.
Author:
Lukas Czaja is Head of Sector Management Machine Tools at Igus.
Energy chains in comparison
© Igus
A study by the Laboratory for Machine Tools and Production Engineering (WZL) at RWTH Aachen University has compared the vibration behavior of five different energy chains. Among others, the E6 energy chains and the 380 series from the E4/00 standard range from Igus were examined. With internal widths of 100 to 105 mm and internal heights of 42 to 52 mm, all the chains tested fell into the same size category. The test rig consisted of a base frame and a highly dynamic direct drive, which moved the linear motor-driven carriage (feed force 14000 N) at four speeds (25 m/min, 50 m/min, 100 m/min, 200 m/min) and with two accelerations (10 m/s², 20 m/s²) over the 800 mm travel distance.
The level of vibration was measured by acceleration sensors with a sampling frequency of 6000 Hz, which were attached to the carrier and the support trough of the energy chains. Separate measurements were taken for the outward and return travel of the carriage in order to avoid confusion of the measured values due to the two directions of movement. The signals recorded by the sensors were evaluated in both the time and frequency domains. In the time domain, the moving effect value (RMS value) is the measure of the vibration energy at the point of measurement.
For all energy chains, the greatest vibration energy was found at the support trough in the direction of the applicator axis (z-axis). Accordingly, the comparative study concentrated on these maximum vibration signals in the z-direction. The different accelerations of 10 m/s² and 20 m/s² had no significant influence on the vibration values of the energy chains.
For the two Igus chains tested, an average 28% lower vibration value was measured than for the other cable carriers. They also exhibited a maximum effective value of around 4 m/s². The 'most vibrating' cable drag chain in this respect had a value of 5.6 m/s², which was 40% worse.
Lapp
Authorized distributors made visible online
Lapp is expanding its digital service portfolio and is the first B2B industrial company to provide its authorized distributors with a verifiable online seal from authorized.by. The company aims to create more transparency and security for buyers and...
Habia
Axel Barnekow Widmark becomes CEO
Habia, a global supplier of customized high-performance cables, announces changes in the company's management: On April 1, Axel Barnekow Widmark took over the position of Chief Executive Officer. He succeeds Carl Modigh, who will remain with the...
Tsubaki cable towing
Avoid wear and tear
Tsubaki Kabelschlepp has added a new function to its condition monitoring system so that wear can also be monitored outside the chain without the need for additional cables in the cable carrier. The system also monitors the push/pull forces during...
Igus
Billion in sales maintained
Despite the challenging geopolitical and economic situation in 2024, Igus was able to increase the number of active customers by 5%. With sales of € 1.105 billion, the company recorded a comparatively moderate decline in sales of 2.5%.
