Energy chains
Quelle: Tsubaki Kabelschlepp | Inka Krischke,
Flexible attachment of drivers
In applications with increased lateral offset, the energy chain guides may be subject to heavy lateral loads. In order to compensate for inaccuracies in the channel alignment or possible wear on the rollers, a flexible carrier connection is required
© Tsubaki cable towing
Tsubaki Kabelschlepp offers the Floating Moving Device for this purpose, which creates a flexible connection between the energy chain and the towing arm of a system. Fields of application for the towing arm connection include crane systems in seawater environments as well as material handling or bulk material applications. The integrated strain relief ensures safe cable routing and high system availability. It can also be combined with the provider's tensile shear force monitoring system. The transverse load-free guidance protects the energy chains and minimizes defects, faults and downtimes. The floating moving device is suitable for the company's M0950, M1250, M1300 and TKHD90 chain types. Its inner width is available in 1 mm increments. The tolerance compensation is at least ±30 mm horizontally.
Lapp
Authorized distributors made visible online
Lapp is expanding its digital service portfolio and is the first B2B industrial company to provide its authorized distributors with a verifiable online seal from authorized.by. The company aims to create more transparency and security for buyers and...
Habia
Axel Barnekow Widmark becomes CEO
Habia, a global supplier of customized high-performance cables, announces changes in the company's management: On April 1, Axel Barnekow Widmark took over the position of Chief Executive Officer. He succeeds Carl Modigh, who will remain with the...
Avoid wear and tear
Tsubaki Kabelschlepp has added a new function to its condition monitoring system so that wear can also be monitored outside the chain without the need for additional cables in the cable carrier. The system also monitors the push/pull forces during...
Igus
Billion in sales maintained
Despite the challenging geopolitical and economic situation in 2024, Igus was able to increase the number of active customers by 5%. With sales of € 1.105 billion, the company recorded a comparatively moderate decline in sales of 2.5%.
