Conec
Available as an overmolded version
Conec has expanded its portfolio of agricultural connectors with overmolded versions of the ATM connector series developed by Amphenol. The series is compatible with the Deutsch DTM connector series.
ATM connector series developed by Amphenol at Conec
© Conec
According to Conec, the connector series is frequently used in process automation and control technology as well as in construction and agricultural machinery and automotive engineering. The cable cross-section for standard parts is 0.5 mm². Other models up to 1.0 mm² are available on request. ATM connectors are specified for a current carrying capacity of up to 7.5 A and are designed as a cable-to-cable connection. The series interlocks securely with the mating connector via a latch without tools. The connection meets the requirements of protection class IP67. The overmolded 2-pin ATM connector is available in female and male versions, both as an open-ended cable and as a connection cable. The open-ended cables with plug (ATM06) or socket (ATM04) can be connected directly to a customer-side plug or to a system of choice. The standard versions are available as open-ended cables in lengths of 2, 5 and 10 m.
SPS 2021
E-Paper THE OFFICIAL DAILY Day 3
The official SPS daily newspaper for you. Issue 3 is also packed full of automation news for you: exciting interviews, new technologies and the latest product innovations. The new interactive e-paper is now available.
