Frequency inverter
Quelle: Emerson | Inka Krischke,
Use in variable-speed drives
Control Techniques has expanded its range of high-power modular drive controllers. The Unidrive M and Powerdrive F300 frequency inverters are available in the larger size 11 for use in variable-speed drives.
© Emerson
Connected in parallel, 'Unidrive M' inverters can control asynchronous and permanent magnet motors with an output of up to 2.8 MW (4200 hp). The inverter is a 250 kW (400 hp) module that enables high-performance drives with the smallest number of modules. An AFE (Active Front End) ensures high torque accuracy and power quality. Depending on the requirements of the application with regard to motor control, the modules can be expanded with the supplier's Unidrive M600, M700, M701 and M702 control/regulator units and controlled via these.
The 'Powerdrive F300' inverter series is available specifically for fan, pump and compressor applications. These devices with their modular design can also control asynchronous and permanent magnet motors.
Drive technology
Triton Partners takes over Flender
Global investment firm Carlyle has signed an agreement to sell Flender, a provider of mechanical drive technology, to Triton Fund 6, advised by Triton. The terms of the transaction were not disclosed and is expected to close in the fourth quarter of...
