Lean technology
Positioning accuracy up to 2 µm
The 'lifgo hp' rack and pinion gearbox from Leantechnik enables long, precise and dynamic strokes. According to the manufacturer, the absolute positioning accuracy is up to 2 µm, a fraction of the thickness of a human hair.
© Lean technology
One of the main reasons for this precision is the helical gearing of the rack and pinion gearbox. According to Leantechnik, it also ensures that the rack moves very quietly and can be loaded evenly. The infinitely adjustable tooth flank clearance also contributes to the precision of the rack and pinion gearbox. In addition to the high positioning accuracy, the rack and pinion gearboxes offer great rigidity, even with long strokes, according to the supplier. The rack and pinion gearboxes in the series are manufactured in various versions with lifting forces between 1,800 N and 22,600 N. The gearboxes achieve a lifting speed of up to 3 m/s and are very compact (maximum 180 mm x 156 mm x 160 mm).
Lean technology
Easy to implement
Handling
High-precision movement of lifting tables
High-precision positioning systems - in the form of lifting tables, for example - are required in order to precisely position car body components for processing in robot welding lines. Gearboxes and precision drive shafts play a 'supporting' role...
Drive technology
Triton Partners takes over Flender
Global investment firm Carlyle has signed an agreement to sell Flender, a provider of mechanical drive technology, to Triton Fund 6, advised by Triton. The terms of the transaction were not disclosed and is expected to close in the fourth quarter of...
