KEB Automation
Drives with air cooling
KEB Automation is expanding its drive portfolio for turboblowers, compressors and other high-speed applications: In addition to liquid-cooled high-speed drives, an air-cooled version will also be available in future.
© KEB Automation
The air-cooled 'Combivert F6' provide outputs of up to 355 kW, output frequencies of up to 2000 Hz and a maximum switching frequency of up to 16 kHz. They are optimized for operation in conjunction with the supplier's 'Combiline Z2' sine filters. As an option, the heat sinks can be routed to the outside through the control cabinet. Thanks to the possibility of parallel connection, outputs up to the megawatt range can be realized.
Drive technology
Triton Partners takes over Flender
Global investment firm Carlyle has signed an agreement to sell Flender, a provider of mechanical drive technology, to Triton Fund 6, advised by Triton. The terms of the transaction were not disclosed and is expected to close in the fourth quarter of...
Humanoids
Schaeffler cooperates with VinDynamics
Schaeffler and VinDynamics, a company of the Vietnamese Vingroup, have agreed on a strategic partnership in the field of humanoid robotics. The collaboration focuses on the development and supply of planetary gearboxes, central components of...
VDW
German machine tool industry stabilizes
After two years of noticeable investment restraint, the German machine tool industry is showing the first signs of stabilization. Overall, however, incoming orders in 2025 remained slightly below the previous year's level.
WEG at the SPS 2025
Smart gearbox selection
'Gear ProSelect' from WEG is aimed at all those who are regularly involved in the selection and design of gearboxes and geared motors in mechanical and plant engineering, including design engineers, technical purchasers and OEMs.
