Take part and winProducts of the year 2023 - your vote counts!
96 products in 12 categories are up for election for the "Products of the Year 2023"! Take part and win Saturn vouchers worth €500, among other things!
9 of 9
Products of the Year 2023 - Nominated in the Embedded Computing & IPC category: OnLogic
© OnLogic
OnLogic - Edge gateway based on the Raspberry Pi
The IGN800 industrial Raspberry Pi edge gateway from OnLogic is certified for the Ignition Edge software from SCADA specialist Inductive Automation. The software is pre-installed on delivery. The gateway is based on the company's 'Factor 201' - an industrial Raspberry Pi computer that is operated with the Compute Module 4 (CM4). The system combines the CM4 with OnLogic's own industrial-grade carrier board and fanless cooling technology. The result is a compact, arm-powered Ignition Edge application that can process 20,000 real-time tags.Ignition from Inductive Automation is an HMI, SCADA, MES and IIoT software platform. It enables users to consolidate different systems into one customizable dashboard. Via the dashboard, users can view and control systems, supply networks or entire municipal infrastructures from anywhere.
>> Go directly to the vote!
9 of 9
