Take part and winProducts of the year 2023 - your vote counts!
96 products in 12 categories are up for election for the "Products of the Year 2023"! Take part and win Saturn vouchers worth €500, among other things!
7 of 9
Products of the Year 2023 - Nominated in the Electromechanics category: Pflitsch
© Pflitsch
Pflitsch - Modular cable entry system
The modular cable entry system CABseal from Pflitsch consists of four different frame sizes suitable for standard cut-outs up to 115 mm × 46 mm. These frames can be variably equipped with four, six, eight or ten grommet fields. This allows a maximum of 40 cables with a diameter of up to 6 mm to be sealed. The tongue/groove contour of the cable grommets prevents incorrect installation. Cable grommets with flexible sealing lip geometry are available in GS sizes for cables with a diameter of 3 to 16 mm and as GL for 16 to 33 mm. Double and quadruple grommets enable increased packing density. The sealing range of up to 1.6 mm and the flexible sealing lip geometry can compensate for cable tolerances of up to 0.4 mm and ensure a seal with protection class IP66/UL Type 4X. The frames made of glass fiber-reinforced polyamide have a molded elastomer seal and are thus sealed against the surface of the enclosure with IP66. The installation height is 20 mm, flush-fitting grommets ensure a closed surface without beading or edges.
>> Go directly to the vote!
7 of 9
