Take part and winProducts of the year 2023 - your vote counts!
96 products in 12 categories are up for election for the "Products of the Year 2023"! Take part and win Saturn vouchers worth €500, among other things!
6 of 9
Products of the Year 2023 - Nominated in the Electromechanics category: Murrelektronik
© Murrelektronik
Murrelektronik - More efficient planning and installation
There is great potential for increasing efficiency in the planning and installation of electrical automation technology. Murrelektronik is therefore presenting a digitally and visually supported system that simplifies the planning and implementation of the electrical installation of machines. The uKonn-X digital solution works as follows: The installer of a machine uses a mobile scanner to read a machine-readable code printed on the Murrelektronik connectors. On a touch display, the digital solution shows which components need to be connected to each other in the scanned circuit diagram and the 3D model of the machine; in the corresponding machine, illuminated LEDs on the corresponding fieldbus modules indicate the assigned port. Once an installation step has been completed, the installer confirms the correct connection on the display and at the same time triggers the automatic documentation. In a nutshell, this means: take component or connector, scan, identify slot via LED, attach or plug in, confirm and trigger documentation. If changes to the installation are necessary, the installer or commissioning engineer can communicate these digitally to the design department using the integrated function.
>> Go directly to coordination!
6 of 9
