Current productsNews from drive technology
Without drive technology - in the truest sense of the word - nothing would turn in most machines and systems. Computer&AUTOMATION presents the latest innovations in this automation discipline in a series of pictures.
Igus has developed the intuitive dryve control system for the maintenance-free "drylin E" linear axes. No software or app is required to enter the data - everything is integrated directly on the motor controller. The values can be entered or changed live in the web browser via PC and mobile devices such as tablets or smartphones. Access can be password-protected, all data and program steps are saved on the control unit and can optionally be stored externally as a parameterization file. The controller is connected to the axis motor and can be mounted on a top-hat rail in control cabinets. This can then be connected via a WLAN router, after which the system can be controlled wirelessly. One controller is required per driven axis, which can be networked with others via a master controller. This means that surface or room portals can also perform complex movements, for example a circular movement.
