Current productsNews from drive technology
Without drive technology - in the truest sense of the word - nothing would turn in most machines and systems. Computer&AUTOMATION presents the latest innovations in this automation discipline in a series of pictures.
16 of 16
16_Allen Bradley Kinetix VPC servo motor from Rockwell Automation
© Rockwell Automation
With Allen Bradley Kinetix VPC servo motors from Rockwell Automation, manufacturers can operate machines at higher speeds and higher torque, thereby improving machine throughput. A motor fan and cooling fins on the motor ensure increased torque and improved power output. The servo motor has various features to reduce machine downtime: According to the manufacturer, larger and robust bearings improve the L10 service life by up to 60 %. A single cable option for power supply and feedback minimizes installation, setup and maintenance time compared to motors with two cables. The fan can be quickly replaced in the field to further maximize machine uptime. The motor series complies with the IE4 standard, which saves energy costs compared to IE3 or lower rated motors. As an alternative to conventional flange mounting, there is an integrated foot mounting option for the motor. The servo motor is currently designed for use with the 'Kinetix 5700' servo drive, but the functionality will be extended to other drives.
16 of 16
