Current productsNews from drive technology
Without drive technology - in the truest sense of the word - nothing would turn in most machines and systems. Computer&AUTOMATION presents the latest innovations in this automation discipline in a series of pictures.
15 of 16
Servomotor HMP15 from Heidrive
© Heidrive
Heidrive is adding the 'HMP15' servomotor with flange dimensions of 150 mm x 150 mm to its portfolio. The company is thus closing the gap between the previous flange dimensions of 130 mm x 130 mm and 190 mm x 190 mm within the 'HMP' series. The changes to the flange have an impact on the connection dimensions, the length and the mass moments of inertia. The new servomotor achieves standstill torques between 20 Nm and 35 Nm. Its power range extends from 3.5 to 7.5 kW. Thanks to the encoder resolution of a maximum of 23 bits per revolution, precise rotary movements and positioning can be carried out in the speed range up to 3000 rpm. Thanks to the supplier's modular system, users can choose from a wide range of encoder and connector options.
15 of 16
