Hanover Fair 2019New products at the industrial trade fair
'Industrial Intelligence' - this is the guiding theme of the Hannover Messe 2019. Computer&AUTOMATION shows an excerpt of the products that can be seen in Hanover in a picture gallery.
13 of 49
New versions of the Vibro vibration meter from Delphin Technology
© Delphin Technology
Following the versions with 8 and 16 vibration inputs respectively, Delphin Technology is now offering two new versions of the universally applicable Expert Vibro vibration meter. Devices with 4 or 12 inputs are now also available. Modern processor technology enables sampling rates of up to 50 kHz per channel. 24-bit A/D converters guarantee high accuracy. It is possible to switch flexibly between the measurement of voltages, currents, IEPE or wave vibration sensors. Integrated comparators and digital inputs allow flexible triggering. Measured values are monitored online and digital outputs can be switched in milliseconds if limit values are violated. In addition to 4 analog outputs for monitoring purposes, two Profibus-DP slave interfaces as well as a Modbus-TCP, Modbus-RTU and a freely configurable CAN interface are also available for fieldbus connection. All signal analysis functions are configured and executed online in the hardware. These include individually parameterizable filters, differentiators, integrators and the FFT calculation. Thanks to an internal data memory of up to 14 GB, the devices can work autonomously. The Vibro option of the ProfiSignal measurement technology software enables the recorded data to be analyzed.
13 of 49
