ABB MotionFrequency inverter controls motors up to 22 kW
ABB is expanding its family of Machinery Drives with a compact, robust and adaptable frequency inverter for machine builders.
10 of 11
© Block
The universally applicable power supplies in the PowerCompactChamp (PCC) series from Block meet the requirements of different applications and industries. With high starting or inrush currents, up to 150 % is available for 5 s and an additional static power reserve of 110 % is permanently available. Thanks to their high efficiency, the power supplies contribute directly to reducing energy costs and CO2 emissions, according to the manufacturer. The compact design saves space on the DIN rail and the reduced device depth enables use in space-optimized control cabinets. According to the supplier, the width of the 240 W devices has been reduced to 40 mm thanks to efficient circuit topologies and an optimized thermal design.
SPS 2022: Hall 4, Stand 410
10 of 11
