Sanyo DenkiDC servomotors with reduced noise level
The Sanmotion K DC servomotors from Sanyo Denki are suitable for applications that require high precision, such as precision measuring instruments or medical devices.
ebm-Papst presents solutions for automation in drive and ventilation technology. These include the ECI-63 internal rotor motors, equipped with an Ethercat interface. High-performance interface electronics including a multi-protocol chip in the drive housing have also been added. The advantages for decentralized drives lie in the synchronization of several axes, the reduced integration effort and a space-saving design in the machine. The new RadiPac series from ebm-Papst can also be used for high-pressure applications. The impeller reduces flow losses and further lowers noise levels.
To accommodate different installation situations, the series is available in a standard and a short version. Both versions are available as a motor-impeller combination or as a ready-to-install plug & play solution with a support spider design. The DiaForce diagonal fan with integrated DC motor enables 50 % more air performance with 6 dB(A) less noise. By sucking in and blowing out air in an axial direction, turbulence can be reduced and the pressure build-up increased. Possible areas of application include data centers or base stations for mobile communications, autonomous driving or artificial intelligence.
SPS 2022: Hall 1, Stand 324
