Sanyo DenkiDC servomotors with reduced noise level
The Sanmotion K DC servomotors from Sanyo Denki are suitable for applications that require high precision, such as precision measuring instruments or medical devices.
Lapp is launching two switches for use outside the control cabinet: thanks to IP67 classification, the Etherline Access PN IP67 Profinet switch and the Etherline Access U IP67 unmanaged industrial Ethernet switch are suitable for use directly in the field. Etherline Access PN IP67 with eight ports (10/100Base-T(X)) for D-coded M12 connectors is particularly suitable for Profinet networks in automation technology (Conformance Class B). It can be used in the extended temperature range from -40 to +75 °C. The managed switch prioritizes Profinet telegrams with real-time data and enables configuration and diagnostics via Profinet or web interface. MRP (client), LLDP, DCP and SNMP are supported. The unmanaged industrial Ethernet switch with eight ports (10/100Base-T(X)) for D-coded M12 connectors has a 16 K MAC address table and 256 Kbyte packet buffer. It is suitable for use in Profinet networks (Conformance Class A) and can be used in the extended temperature range from -40 to +75 °C.
SPS 2022: Hall 2, Stand 310
