Nasa electric aircraft X-5714 Propellers instead of two
As part of the 'X-Plane for Experimental Aircraft' program, researchers at the US space agency NASA are working on an aircraft that does without combustion engines and is powered purely by electricity: with a multi-propeller system integrated into the wing.
5 of 7
Rendering of the planned X-57 Maxwell electric aircraft
© Nasa Langley / Advanced Concepts Lab, AMA, Inc.
... electric aircraft of this type can be up to 40 % cheaper to produce than conventional ones. The X-57 is powered by a rechargeable battery. It therefore has no combustion engine as a range extender or for recharging the on-board battery. The aircraft is expected to make its maiden flight next year and will be the same size as conventional private aircraft. The picture shows a rendering (as well as picture 1 in this series). Nasa researchers are currently testing the prototype ...
5 of 7
