IAA Commercial Vehicles 2016
Daimler shows all-electric truck
With the Mercedes-Benz Urban eTruck, Daimler Trucks is presenting a fully electric truck with a gross vehicle weight of up to 26 tons for the first time. The market launch of this technology is conceivable for the manufacturer at the beginning of the next decade.
With the Mercedes-Benz 'Urban eTruck', Daimler is presenting a fully electric truck for heavy-duty distribution transport.
© Daimler
The technical starting point for the 'Urban eTruck' is a heavy three-axle distribution truck from Mercedes-Benz. However, the developers at Daimler Trucks have also rethought the drive concept: the entire conventional drive train is replaced by an electrically driven rear axle with electric motors directly next to the wheel hubs. Their maximum output is 2 x 125 kW, the maximum torque 2 x 500 Nm. In conjunction with the gear ratio, the torque at the wheel reaches 11,000 Nm.
The energy supply is provided by a battery pack consisting of three modules of lithium-ion batteries with a total capacity of 212 kWh, which are housed crash-proof within the frame. This results in a range of up to 200 km - which corresponds to a typical day trip in distribution transport. The modular battery configuration can be individually adapted by adding or removing battery packs, depending on the desired range.
The 'Urban eTruck' is connected to the charging station via the Europe-wide standardized CCS type 2 plug. With a charging capacity of 100 kW, the completely discharged batteries are 100% full in two to three hours.
The drive of the 'Urban eTruck' consists of an electrically driven rear axle and electric motors directly next to the wheel hubs.
© Daimler
Siemens
Erster europäischer "Electric Highway"
Siemens realisiert in Schweden und damit erstmals in Europa ein Oberleitungssystem mit Hybrid-Lkw. Zu Demonstrationszwecken wird dazu ein zwei Kilometer langer Abschnitt der E16 nördlich von Stockholm über ein Oberleitungssystem elektrifiziert.
