igus
Construction kit for cobot ideas
Igus is launching a modular gearbox system for cobots on the market. It consists of tribo-shaft gearboxes in sizes 80 and 105 with integrated motor controller, force control electronics, absolute encoder and motor.
© igus
The gearbox uses a Tribo shaft generator and Tribo flex ring with external gearing as well as an external rotor brushless DC motor. An individual robot can be constructed on the basis of the gearbox using connecting elements, and thanks to the additional electronic components it can also be used as a cobot.
Thanks to the electronic components in the fully integrated shaft gearbox, HRC capabilities are possible. Using absolute value encoder technology, forces and torques can be determined and safely limited via the motor current. To do this, igus relies on a double encoder that measures in front of and behind the joint in order to detect and react to forces and torques.
Igus
Robotics award enters second round
For the Roibot Award 2022, Igus is once again looking for creative applications worldwide, or more precisely, for existing low-cost automation applications that have led to a rapid return on investment.
Fraunhofer IFF
Secure cobot installations
When it comes to safety, cobots place high demands on the knowledge of their human colleagues. A digital service developed by European research institutions aims to help companies share knowledge and carry out safe cobot installations.
Kuka at Infineon
Cobots automate cleanroom
At Infineon's semiconductor production facility in Villach, 17 sensitive lightweight robots from Kuka work safely together with humans and machines to ensure greater efficiency and safety in the manufacture of highly fragile wafers.
WEG at the SPS 2025
Smart gearbox selection
'Gear ProSelect' from WEG is aimed at all those who are regularly involved in the selection and design of gearboxes and geared motors in mechanical and plant engineering, including design engineers, technical purchasers and OEMs.
