Motor controls
Quelle: Igus | Inka Krischke,
Change values via smartphone and tablet
Igus has developed the intuitive dryve control system for the maintenance-free 'drylin E' linear axes. No software or app is required to enter the data - everything is integrated directly on the motor controller.
© Igus
The values can be entered or changed live in the web browser via PC and mobile devices such as tablets or smartphones. Access can be password-protected, all data and program steps are saved on the controller and can optionally be stored externally as a parameterization file. The controller is connected to the axis motor and can be mounted on a top-hat rail in control cabinets. This can then be connected via a WLAN router, after which the system can be controlled wirelessly. One controller is required per driven axis, which can be networked with others via a master controller. This means that surface or room portals can also perform complex movements, for example a circular movement.
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
