Danfoss
Günter Herkommer,
Aiming for medium voltage
Danfoss came to Nuremberg with a real heavyweight - the Vacon 3000 - with which it intends to tap into a new market in the future: the medium-voltage inverter business. Product Marketing Director Hans Carlsson explains the background.
Hans Carlsson: "We want to become one of the most important suppliers for medium voltage, just as we are for low voltage."
© Danfoss
Mr. Carlsson, Danfoss and Vacon have so far only been active in the low-voltage range with their frequency inverters. What prompted you to now also tackle the medium-voltage sector?
Carlsson: Following the acquisition of Vacon, Danfoss has become one of the largest manufacturers of low-voltage inverters. However, many of our customers and partners also use medium-voltage inverters and we want to serve them with a complete product range in the future. We also see that the market for medium-voltage converters is becoming increasingly important. Although the inverter market generally remains constant, we estimate that the global market for medium-voltage inverters is now worth more than two billion euros!
What specifically characterizes your new medium-voltage inverter?
Carlsson: The Vacon 3000 is built in several versions. The aim for us was to have a product range with which many different requirements can be optimally solved. The standard versions include both a cost-efficient 12-pulse version and an active front end. The latter is ideal for applications where either recuperative braking is required or the lowest possible distortion factor for the current is important.
The complete product range is water-cooled and available in two different voltage versions: 3.3 kV for the global market and 4.16 kV mainly for the North American market. The initial power range is from around 2 MW to 6 MW motor output, with higher outputs planned for the future.
The medium-voltage market is already heavily occupied by other market players. What unique selling points does Danfoss want to use to get a 'foot in the door' here?
Carlsson: Up to now, medium-voltage inverters have been supplied almost exclusively in standard control cabinets. The situation is very different for low-voltage inverters, as system integrators and machine builders in this segment often prefer their own installation solutions because these can be better adapted to specific requirements. This is precisely why Danfoss offers a modular concept for medium voltage with the 3000 series, just like for low voltage. To put it bluntly, this makes things possible that were previously not possible in medium voltage. In other words: Because Danfoss only supplies the pure installation modules, our partners can design their own housings or cabinets to best suit the application. For example, there are many applications where the installation height or length is limited or where there are special requirements, such as in terms of vibrations.
Which applications or sectors are you specifically targeting?
Carlsson: We imagine that the Vacon 3000 will mainly be used for applications in marine & offshore, mining, oil & gas and heavy industry. However, there are certainly other potential applications that we have not yet thought of.
Start-ups
The 'Automation Hackathon'
At the 'Automation Hackathon' at SPS IPC Drives 2018, seven start-ups had the chance to develop new business models for selected companies in the automation industry in 48 hours. Winner: the start-up Othermo in collaboration with Wago.
Synapticon
Entering the Machine Building Business
Known as a technology supplier to robot manufacturers, Synapticon now plans to offer targeted solutions for machine builders. The kick-off was given at the SPS IPC Drives with the ‚Actilink‘ drive systems and a quick-start package for the production...
Faulhaber
The winding does it!
With the market launch of the new brushless DC motor family BXT, Faulhaber is setting new standards in the field of external rotor high-performance drives. The winding plays a central role in this.
