Sick
Paving the way for digitization
'We Create Digital Transformation' was Sick's trade fair motto to present intelligent sensors as pioneers of digitalization as well as digital services and software solutions based on their data.
The multifunctional sensor 'FTMg' simultaneously measures and monitors the flow rate, temperature and process pressure of non-corrosive gases.
© Sick
Data forms the basis for digitalization in the industrial environment. It is collected in machines and systems by smart sensors, pre-processed into valuable information using special algorithms depending on the task and then transmitted. One example of this from Sick is actuator diagnostics with the intelligent cylinder sensor 'MPS-G'. In gripping and handling processes, the sensor is able to monitor vibrations, avoid collisions and detect temperature changes that indicate wear or a reduction in gripping force. The data generated is made available to higher-level systems - a PLC, an MES, an ERP system or a cloud application - via intelligent integration. In this way, the actuator diagnostic data can be used for condition monitoring.
Existing machines and systems can be retrofitted to make them fit for the digital age. With the 'TDC-E' gateway, for example, it is possible to analyze recorded production data and make it available for networked communication between systems and higher-level systems, such as an MES, an ERP system or a cloud.
There are also solutions from Sick for new applications, such as in the field of energy management systems: the 'FTMg' multifunction sensor, for example, is used to simultaneously measure and monitor the flow, temperature and process pressure of non-corrosive gases in pneumatic systems, including leakage monitoring.
Often a solution must also be 'safe'. This is why Sick presents itself as a provider for navigation, positioning and load handling as well as safety, for example in the field of driverless transport systems and autonomous mobile platforms. One example is the 'outdoorScan3' safety laser scanner.
Data and information from smart sensors form the basis of Sick's Smart Services. Digital services and software solutions make production, handling and process sequences transparent and therefore optimizable. For example, 'Filling Level Monitoring', a digital service specially designed for packaging machines, monitors the filling levels of cardboard packaging, liquids or granulates independently of the machine manufacturer, aggregates this data and makes it available at any time and from anywhere via a cloud service. With the 'Quality Inspection' sensor app, a user knows that products meet the exact requirements after production. The information on dimensions and presence is provided by 2D cameras from the 'InspectorP6xx' product family. Other smart services make it possible to optimize material flows, identify and locate load carriers and products or intelligently automate shelving systems.
Sick
Works in confined spaces
With the InspectorP61x, Sick is launching a compact all-in-one 2D vision sensor that enables inline vision inspections even in the tightest of spaces or mounted on robots.
