Turck
Inductive IO-Link sensors with analog output
Turck is expanding its sensor range to include measuring inductive sensors with IO-Link and analog output for flush and non-flush mounting.
© Turck
According to the manufacturer Turck, the 'BI11-CK40' and 'NI11-CK40' models offer significantly improved linearity and accuracy including temperature compensation over a temperature range of -25 to +75 °C thanks to the integrated microprocessor. The sensors have a classic, adjustable voltage output from 0 to 10 V on the one hand and an additional switching output that can be freely parameterized via IO-Link and provides measurement data and diagnostic functions for predictive maintenance on the other. In addition, the simple parameter transfer via IO-Link facilitates sensor replacement in the event of a fault and minimizes downtimes in production. With a range of up to 25 mm and a linearity deviation of less than 1% for the flush version and less than 3% for the non-flush version, the robust IP67 sensors are suitable for a wide range of applications, for example in the mechanical engineering, packaging, energy and automotive sectors. The cuboid CK40 design creates space for space-saving, flexible and easy-to-implement mounting solutions. The sensor head can be positioned in five directions using the tool supplied.
Turck
Paving the way for Industry 4.0 and IIoT
Automation solutions from Turck support the profitability, efficiency and sustainability of machines and systems. In this way, they not only increase competitiveness, but also contribute to more environmentally friendly production and intralogistics.
Turck
Paving the way for digital transformation
