Product presentationsNews from the field of sensor technology
580 exhibitors will be showcasing their latest products from the world of sensors at Sensor+Test at the end of June 2018. Computer&AUTOMATION shows a selection of these in a picture gallery.
7 of 11
7_Encoder for magnetic absolute measurements from Bogen Electronic
© Bogen Electronic
Bogen Electronic's AKP18 is an encoder for magnetic absolute measurements. With a length of 22 mm, a width of 6 mm and a height of 3 mm, the encoder can be implemented even in the smallest installation spaces. Its resolution is 18 to 20 bits. When using the BISS-C output configuration, up to eight encoders can be connected in series. Due to its small size, the higher resolution and the accuracy of the encoder, the previous design options are extended, especially for robot manufacturers. For example, the use of rotary scales of <13 mm with a resolution of 18 bits is possible. At the same time, there is the option of a through-hole configuration for cables and other components.
7 of 11
