Product presentationsNews from the field of sensor technology
580 exhibitors will be showcasing their latest products from the world of sensors at Sensor+Test at the end of June 2018. Computer&AUTOMATION shows a selection of these in a picture gallery.
The CMOS line sensors from the iC-LFH series from iC-Haus are available in four different lengths with 320, 640, 960 and 1024 pixels. They work with a pixel clock of up to 5 MHz. The 600 µm long pixels in a 12.7 µm grid (2000 DPI) are arranged without gaps or distortion thanks to monolithic integration and are therefore particularly suitable for triangulation or spectroscopy applications, for example. The integrated control logic requires only one start and one clock signal for the output of the light/voltage conversion at the analog output. Thanks to the asynchronous, global, electronic shutter, the exposure time can be variably controlled. The physical resolution of 2000 DPI can be electronically reduced by a factor of 2, 4 and 8, for example to perform a quick rough scan.
