Current productsNews from sensor technology
What would the smart factory of today and tomorrow be without sensors? Sensors are indispensable as the basis of every industrial production system. Computer&AUTOMATION has summarized current trends in a picture gallery.
9 of 16
Flow meter/flow counter called FVone-NP-CA from FlowVision
© FlowVision
FlowVision has a compact calorimetric flow meter/flow counter called FVone-NP-CA for air, nitrogen, oxygen, argon, carbon dioxide and methane in its range. The sensors and the housing are made of stainless steel 1.4571 as standard, special materials such as Hastelloy, titanium or a tantalum coating are possible. The flow meter has two analog outputs 0/4 to 20 mA for flow and temperature, two relay outputs, a quantity-weighted pulse output and an error message output. The sensor is configured via USB using PC software. The device is available as a screw-in version (G ½ inch), as a push-in version (installation with compression fitting) and as a plug-in version for sensor adapter TP or ball valve BV. The sensor can also be installed or replaced under pressure.
9 of 16
