Product presentationsNews at the Sensor+Test 2016
From May 10 to 12, around 580 exhibitors at Sensor+Test will be presenting their latest products from the fields of sensor and measurement technology. Computer&AUTOMATION shows a selection of these in a picture gallery.
16 of 18
17_Three new sensor models from TWK-Elektronik
© TWK-Elektronik
TWK has added three sensor models to its range of safe SIL2-certified encoders and cam switch units: the TRK/S3 absolute multiturn encoder (pictured left) with Safety over Ethercat interface (FSoE) completes TWK's series of magnetic encoders. It enables the safe monitoring of the position and speed of a system. The FSoE protocol runs on the standard Ethercat, so that non-safety and safety devices can be operated in the same Ethercat network The SIL2/PLd-certified HBN/S3 single-turn encoder with CANopen safety interface is available in the series of high-resolution magnetic encoders. It offers a resolution of up to 22 bits per turn. Last but not least, the range of inclination and vibration sensors has been expanded to include the safe vibration transducer NVA/S3 (pictured right). This can safely detect vibrations in the range 0.1 to 60 Hz and output them via CANopen Safety or analog. It also has two SIL2/PLd-certified switching contacts that safely switch off the system if the acceleration warning and alarm values are exceeded. The calculation of the frequency spectrum of the acceleration signal using Fourier analysis is in preparation.
16 of 18
