JumoGroup continues to grow
A 6% increase in turnover and an interesting range of new products at Hannover Messe 2019 - the Jumo Group had a lot to report at its annual press conference.
'Dicotemp 100' is a smart fitting with which a diverse temperature measurement can be realized with a thermostat or dial thermometer and a platinum chip temperature sensor at just one measuring point. The resistance signal is converted into an analog or digital signal via a measuring transducer. With this device, users can continue to use devices already installed in the process at the same measuring point and at the same time expand their functionality to include electrical temperature measurement. The combination of a platinum chip temperature sensor with a thermostat or dial thermometer in a fitting reduces planning and installation costs. The fitting is made of stainless steel and is available in various connection types - for screwing in or for plugging into a smooth pipe. The installation length varies between 65 and 300 mm, depending on customer requirements. Process temperatures between -40 and +260 °C are possible
