JumoGroup continues to grow
A 6% increase in turnover and an interesting range of new products at Hannover Messe 2019 - the Jumo Group had a lot to report at its annual press conference.
Another new product is the 'Logoscreen 700' paperless recorder with intuitive operation. The high scalability of the measuring input and output cards enables flexible adaptation to different applications. The range of equipment options extends from a device version without a measuring input to versions with a maximum of 18 measuring inputs, three analog outputs, 18 digital inputs, 24 individually switchable digital inputs or outputs and seven relay outputs. The shallow depth of 119 mm saves space during installation. Commissioning is carried out with the aid of push-in terminals. The 5.7-inch TFT color graphic display has a touchscreen. The intuitive, icon-based system means that in most cases a maximum of three "touch movements" are sufficient to display the required process data. Up to 60 analog and digital channels can be recorded via a Profinet interface and 120 external analog and digital inputs can be displayed. Up to eight counter inputs enable flow measurement based on fast digital pulse generators.
