ipf electronic at the SPS 2022Detection with UV light
The OY380520 and OY380523 luminescence scanners from ipf electronic are optical sensors that use UV light to detect luminophores in different materials, thereby triggering a switching operation.
Based on its Industrial Ethernet platform, Kübler presents the first safe SIL3-certified encoder. The Sendix S58 Profisafe is available in size 58 mm as a singleturn and multiturn in a shaft or hollow shaft version. It transmits up to 16 bits safe or up to 24 bits non-safe as well as additional multiturn information of up to 12 bits safe in the fully redundant multiturn version. The encoders are equipped with the certified encoder profiles (Profinet v2.35/ Profisafe profile v2.6, Profidrive profile v4.2, Encoder profile v4.2,). They correspond to encoder class 4/ S2 and provide the recorded measurement and diagnostic data via safety telegrams 36/37 or non-safe telegrams 81, 82, 83, 84, 86, 88. The CRC calculation for confirming the F parameters is implemented via a Tool Calling Interface (TCI). The calculation program can be started directly from TIA Portal. The integrated iPar server reduces errors and commissioning times when replacing devices, and a web server is also integrated.
SPS 2022: Hall 7A, Stand 506
