Baumer for SPS Connect
Detects the smallest objects down to 0.05 mm
The optical O200 miniature sensors with focused laser light beam from Baumer enable even greater precision in the detection of the smallest differences in position, gaps and small parts such as individual wires or the finest threads with a diameter of just 0.05 mm.
© Baumer
The sensors work reliably even under the influence of strong ambient light such as LED lighting, machine reflections or mutual interference from other sensors.
Thanks to their unique range of 180 mm, the laser variants with background suppression are suitable for pinpoint detection of the smallest objects in material feeding or the electrical industry, for example. Maximum reproducibility is ensured by a minimum jitter of less than 20 μs, which enables high-precision triggering. Thanks to the extra power reserves (high-power mode), they also detect deep black or angled objects at distances of up to 180 mm.
In addition to the laser dot variants, the Baumer portfolio offers sensors with a 56 mm long laser line. These sensors detect a much wider area and thus compensate for smaller punched-out areas or holes, such as on printed circuit boards. Laser retro-reflective sensors with single-lens optics can reliably detect objects even through very small openings thanks to the transmitter and receiver beam on one axis.
Would you like a little more?
First-hand news every week - that's what the Computer&AUTOMATION newsletter offers you.
© WEKA Trade Media
Subscribe to our newsletter and keep your finger on the pulse of automation. Stay up to date with us. We provide you with the latest news, exciting interviews, guest commentaries, application-oriented technical reports and new products.
Click here to subscribe.
Baumer
Reliably recognize the finest details
Baumer is expanding the 10 GigE cameras in the 'LX' series with four new models. The cameras with Sony Pregius S sensors deliver 50 fps at 24 megapixels; more resolution is available with the 65 megapixel Gpixel models at 18 fps.
Baumer
A perfect fit in five steps
Laser distance sensors ensure process efficiency in automated production processes with the help of non-contact measurements. When choosing the right sensor, factors such as measuring range, focus, beam shape or object surface as well as ease of use...
Baumer
Measured value is available in 15 s
The CombiLyz conductivity sensor from Baumer helps with the phase separation of food, water and cleaning liquids. It measures the electrical conductivity of the passing medium and draws conclusions about the type of medium and its concentration.
