Euchner at the SPS 2022Safety switch with 'FlexFunction'
The CTS safety switch from Euchner can be used for swing or sliding doors or for the smallest door radii.
4 of 19
Kontron_PS_2022
© Kontron
Kontron presents the KBox R-101 with EN 50155 certification and 5G connectivity. The control and communication platform in box PC format is based on a fanless, passively cooled and IP54-compliant system solution with industry-approved mechanical and electronic components. The system and all external interfaces are suitable for use in harsh industrial environments and public transportation. Based on the eleventh-generation Intel Core i7-1185GRE processor and a maximum memory expansion of 32 GB, the platform supports OEM manufacturers and system integrators in setting up system solutions. On the front, it has three Gigabit Ethernet interfaces M-12 x-coded, two serial I/Os and a USB-C interface. There are also six cut-outs for antenna connections as well as seven LEDs, which can be used for specific applications, and a power LED. The system is designed for operation in a temperature range between -40 and +70 °C.
SPS 2022: Hall 7, Stand 193
4 of 19
