Sigmatek
Real-time software for AGVs and AMR
With TCS (Traffic Control System), Sigmatek offers an open fleet management system for integrating AGVs and AMRs into shared AGVs and connecting them to the surrounding IT and automation systems, regardless of their make.
© Sigmatek
The VDA 5050 interface, as well as VDA 5050, MQTT, JSON, UDP and TC/IP are used for communication between the vehicle and the control system. The 'SlamLoc' real-time positioning software from Sigmatek helps AMR to deal with changes in its environment during contour-based navigation. It works without pre-installed plans and determines a pose that is accurate to ±10 mm and ±1° in real time, even when contours change significantly. During the initial teaching run, the software creates a map of the surroundings as a basis for route planning. If a 'foreign object' is detected during a subsequent trip, it is temporarily taken into account and used to determine the position. Based on the SLAM data, the controlling systems can react immediately and determine the best possible route and avoid obstacles or take alternative routes.
Sigmatek
Remote access
With the 'Remote Access Platform (RAP)', Sigmatek offers a secure, web-based option for remote services - from monitoring and remote maintenance, debugging and commissioning to software updates or data insights.
Sigmatek
Visualize movement
Aluminum windows are precision components whose accuracy of fit contributes to the energy efficiency of a building. Highly automated production with a sophisticated drive and operating concept helps to maintain high quality standards.
Logimat 2025
Intralogistics Next Level
Logimat 2025 will occupy all ten halls of the Stuttgart exhibition grounds from March 11 to 13. Global players, medium-sized companies and start-ups will provide an overview of the current state of the art in the intralogistics sector.
